[Rozwiązany] Very early assembly question
Matt L
(@matt-l)
Hi everyone,
Just got the original MK3s kit. I am pretty early on in the assembly (preparing Y-belt idler) and I'm having trouble getting the M3nN nyloc nut to stay inside of its slot. I tried screwing in the M3x18 screw and holding the nut with tape, but it does not go in. Based on the instructions the nylon fitting in the interior should face outside of the belt idler. I'm sure there's a simple solution, but want to make sure I don't overtighten or anything and break the 3d printed part.
Thanks!
Opublikowany : 16/02/2021 5:29 pm
Matt L
(@matt-l)
RE: Very early assembly question
Nvm, I figured it out. Just needed a little sanding!
Opublikowany : 16/02/2021 6:32 pm
