Unload filament, load filament loop
Stránka 2 / 2
Sanded157
(@sanded157)
RE: Unload filament, load filament loop
Just like most of you I had the same problem. And ill be the first to admit i did a horrible job of reading the instructions. But the picture does show it in the top plug but the BOLD capitalized letters do say to use the bottom
Napsal : 04/03/2020 7:47 pm
Ronnie
(@ronnie)
@oliver-a5
Is it when you looking at the front of your printer?
Napsal : 16/05/2020 4:01 pm
Ken Hammond
(@ken-hammond)
I had the same problem. My IR sensor cable was plugged into the top row of the connector, instead of the bottom row. Once I figured that out, it worked fine. I'm not sure why they allow you to plug it into the wrong row in the first place.
Napsal : 14/12/2020 5:13 am
Jnk2212
(@jnk2212)
Another cause of this issue: I'm trying to print Nylon from trimmer line with a diameter of only 1,4mm (this is what I had lying around). This seems to be too low and triggers the filament sensor. Just disable it.
Napsal : 11/06/2021 7:42 am
4L4RIC
(@4l4ric)
I discovered that I put the IR cable in backwards into RAMBo board: the red and black wire should be to the right; I had them to the left.
I did the same thing, quick flip and the load/unload loop is solved.
Napsal : 12/11/2022 3:01 am
Stránka 2 / 2
