underextrusion?
Ladrogue
(@ladrogue-2)
underextrusion?
dear all! just build my first mk3s+ about 3 days ago. the problem is that it seems like i got some underextrusion. i rechecked the gears and the tension of the extruder. i also tried different filaments and the settings are original without changes. can anybody tell me whats wrong here? i also tried it with the original smooth sheet with the same result.
best regards! 🙂
Respondido : 18/09/2022 8:44 am
Thomas Lynch
(@thomas-lynch)
RE: underextrusion?
Looks like your Calibration is off. Try doing it again.
Respondido : 18/09/2022 8:00 pm
Ladrogue
(@ladrogue-2)
RE: underextrusion?
i already recalibrated. and if i go lower i got a very unclean surface in the first layer so i see that it is too low. well i am not a pro in 3d printing but if the surface gets unclean it means that it is too low right? i also have no clean walls. and i think i can remember that those problems are a sign for underextrusion or i am wrong?
Respondido : 19/09/2022 1:46 pm
Check the grub screws in your belt-driver pulleys, they MUST be tightened in sequence as in the instructions.
IF they are correct check your belt tensions.
Respondido : 19/09/2022 4:03 pm
Ladrogue
(@ladrogue-2)
RE: underextrusion?
you mean tighten first that one on the small flat part then the other screw? thats the important thing? i did that but i can recheck again.
Respondido : 20/09/2022 8:20 am
boinappi
(@boinappi)
RE: underextrusion?
for me it seems your printer can not build up pressure fast enough (small holes in surface connecting to perimeters).
Bed level seems okayish to me - i'd focus on the extruder.
  • listen closely (clicking noises) and check if your filament is grinded
  • check extruder tension
  • is your filament path clean?
  • can your spool run freely?
  • perform a cold pull to clear a potential partial clog (highly recommend this)
  • filament with high diameter tolerance? (not likely)
Let is know if you succeeded!
You got this!
Respondido : 26/09/2022 8:08 am
