Unable to print anything with new assembled box
eric
 eric
(@eric-11)
Hi!
I'm sure this is my fault but I can't figure out how to get my filament loaded into the device. I watched the videos and used the unloading function to remove the filament that shipped poking out of the extruder, but now I can't seem to load the filament that I cut into a point into the machine and nothing is coming out of the extruder.
I don't understand what to do next.
Napsal : 04/06/2021 9:22 pm
RE: Unable to print anything with new assembled box
About 5 minutes in.
Napsal : 04/06/2021 10:02 pm
Dan Rogers
(@dan-rogers)
On the menu there is a choice for auto-load filament.  That will cause a second  prompt if you click it asking for what temperature/material you want to load.  If you do not select a filament type, it will not heat up and will not load filament.
Napsal : 05/06/2021 9:30 am
