Unable to duplicate print
PS
 PS
(@ps)
Hi guys,
I printed the Prusa logo twice on an MK3s+ with everything being the same (settings, temperature, material etc.), but the results look very different and the bottom logo is not very stable. Any suggestions on how I can fix this?
Cheers,
Paul
Postato : 14/01/2021 5:54 am
Utenti
RE: Unable to duplicate print
If eyes are not failing me, That is under extrusion.
https://help.prusa3d.com/en/article/under-extrusion_2007
Postato : 14/01/2021 10:57 am
PS hanno apprezzato
Peter M
(@peter-m)
You could have a partial clog.
Move extruder to high position and extrude, look if it extrudes, thick enough, straight down, no bubbles(water in filament).
Do a few cold pulls, see the manual on the prusa website how to do this.
Then make a first layer, and let the forum see your first layer, make a picture. On youtube you see examples how it should look like.
If first layer is to high you can get bad prints.
Important for printing is :
1. clean bed, use only dish soap, do not touch the bed.
2. First layer needs to be perfect, then your print will not release wen printing, and avoid a big ball of filament sticking to the nozzle.
Both settings are for getting a good sticking to the bed.
Postato : 15/01/2021 9:23 pm
PS hanno apprezzato
PS
 PS
(@ps)
@peter-m-3
Thanks so much for your feedback. After the cold pulls, the filament extrudes straight down now  👍
Here's an image of my first layer:
Postato : 15/01/2021 11:31 pm
Utenti
@ps-3
One other thing that might help you is to buy some purge filament to use when you change filament.
Postato : 15/01/2021 11:59 pm
Peter M
(@peter-m)
First layer looks good.
Does the print work now?
Postato : 16/01/2021 5:19 am
PS
 PS
(@ps)
@cwbullet: Can you recommend any specific purge filament? Which material does it need to be out of?
@peter-m-3: Unfortunately not. As soon as it gets to the second layer, things start to get really messy.
Postato : 16/01/2021 6:40 am
Peter M
(@peter-m)
Try to print with higher extruder temp.
Try print slower.
Are the springs on the extruder, set as in the manual?
Did you try different filament?
Print a few square models, to test the first layer, start to high and print every square a little lower(the first layer), then see which is best, to low is not good model can come loose higher up in the print.
Postato : 16/01/2021 12:59 pm
PS hanno apprezzato
PS
 PS
(@ps)
@peter-m-3 You are correct, the spring wasn't tight enough. Thanks for the suggestion!
Now I finally got my first decent looking print, however it still has a few minor flaws. Any suggestions on how I can fix these?
Postato : 17/01/2021 5:38 am
Utenti
Snips and a heat gun.
Postato : 17/01/2021 2:24 pm
PS hanno apprezzato
