Trouble with Calibrate XYZ—How to Correctly Adjust SuperPINDA Probe?
I have finished assembling my new MK3S+; it passes self-tests but I am having trouble with the Calibrate XYZ step. The nozzle drags the paper. I understand that I'm supposed to lower the SuperPINDA probe, but I'm having difficulty moving the probe in small increments. Is the probe supposed to screw up or down in its socket (which would twist its cable) or is it supposed to be pushed/pulled straight up or down?
Publié : 15/06/2021 11:18 pm
RE: Trouble with Calibrate XYZ—How to Correctly Adjust SuperPINDA Probe?
When I did mine I released the screw pretty far out and then braced the bracket with one hand and pushed with the other onto the zip tie
Publié : 16/06/2021 7:38 am
