Trouble printing after changing to a different PLA
Matthew Guerin
(@matthew-guerin)
Hi - new 3d printer user here. I am a high school teacher and bought the Prusa i3 MK3S+ this year and just finished the roll of PLA it came with. We had extra PLA from a previous teacher so I reloaded with that. It is not Prusa brand -  it is 3D fuel Pro PLA. It was fine for a while, but I am now having trouble with my prints - see the pictures for reference. I am using the default PLA settings. Any idea what settings I might have to change to get a better print? Thank you!
Postato : 06/04/2023 9:18 pm
jsw
 jsw
(@jsw)
RE: Trouble printing after changing to a different PLA
Two things I would quickly check.
1. Be sure that your Z calibration is spot on.  Some filaments are more finicky than others.
2. You might try drying the left-over spool, particularly if it has been exposed to room air.  A food dehydrator works quite well, or, lacking that, an electric (NOT GAS) oven set low, to maybe 120-130F (49-55C).
Postato : 06/04/2023 11:02 pm
Hello
(@hello)
yep i would defintly say damp fillament i agree with you jsw
Postato : 06/04/2023 11:10 pm
Matthew Guerin
(@matthew-guerin)
Ok I will try that out, thanks for the quick response!
Postato : 06/04/2023 11:21 pm
Hello
(@hello)
thats all good do let us know when you have done it and photos even if it does work please still add photos and we might be able to give advice on prints
Posted by: @matthew-guerin
Postato : 06/04/2023 11:22 pm
Matthew Guerin
(@matthew-guerin)
Ok checking back in - I was able to successfully print the parts. I turned off the printer for a while, then turned it back on and cleaned the nozzle. After that I used the Live Z adjust and changed it from -1.400 to -1.415 which didn't seem like much of a change. I didn't have access to a dehydrator. That is the only thing I changed - see the images for the results.
I did seem to have some warping and a line form on one of the parts. Let me know if there is something I should do differently to fix that. Thanks again for the help!
Postato : 07/04/2023 1:03 pm
René
(@rene-3)
That line you see is also called 'buldge'.
You can find a lot about this problem here.
Postato : 07/04/2023 2:57 pm
