Trouble installing f-s cover
Nearly finished extruder though I can't seem to move nut to get f-s cover on. Can only seem to see the outside edge of the nut. Please help. Thanks
P.s. I've Tried moving it with Allen key and larger screw
RE: Trouble installing f-s cover
I assume you mean on the MK3, but this looks like it's in the Mini forum.
The fan shroud was the most tricky part to get oriented correctly. I loosened everything and very carefully compared what I had with the photos and very carefully coaxed everything into place.
Yup, totally posted this in the wrong spot sorry.
Ended up getting it after an hour of fiddling, just finished the whole assembly today. Looks awesome.
Thank you
Moved!
Joan
