Trouble getting anything to print: New i3 MK3 assembled
dennis.c2
(@dennis-c2)
Hi -
I could use a bit of help - I have a newly arrived Prusa i3 MK3 printer that arrived fully assembled. I have been trying off and on for 30 days to get a sold print with no luck. I have read the manual - completed dozens upon dozens of calibrations - updated firmware etc.
So - here is the data - running firmware 3.1.3-245
I am using 1.75mm PLA that came with the printer.
When I print anything - it just bundles up on the extruder.
Here is a picture of the "PRUSA Badge" -
https://www.flickr.com/gp/dennisjamescox/F7ky39
The calibration keeps resulting in a slight bend of the boxes
https://www.flickr.com/gp/dennisjamescox/x2y80J
I have tried 0mm on Z , -100mm on Z, -200mm on Z and -500mm on Z with the similar results. I assume there is something major that I am missing.
I have cleaned the extruder - I have done both cold pulls - and normal unloading and heating and wiping.
Any suggestions would be much appreciated.
Dennis
Opublikowany : 18/04/2018 8:31 pm
Nikolai
(@nikolai)
Re: Trouble getting anything to print: New i3 MK3 assembled
Hello Dennis,
your z-height is still too high and the filament is not sticking to the bed. Adjust the live z-height until you can see the filament is squished like explained in the guidelines.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 18/04/2018 8:41 pm
dennis.c2
(@dennis-c2)
I'll go even lower - thank you the quick reply
Opublikowany : 18/04/2018 9:01 pm
dennis.c2
(@dennis-c2)
That did the trick! -.800mm
Opublikowany : 18/04/2018 9:59 pm
Nikolai
(@nikolai)
Glad to hear that. Happy printing 🙂
Often linked posts:
Real Multi Material
Opublikowany : 18/04/2018 11:44 pm
