RE: Top layer tweaking
Two tips:
- Use Monotonic top infill pattern.
- Calibrate your extrusion multiplier to reduce slight over extrusion which can create ridges along top surface.
Veröffentlicht : 27/01/2021 7:58 pm
@bobstro
- It's already Monotonic. I used the 0.20mm Quality preset from PrusaSlicer without much modification.
- I'll try to find a guide on how to do this. Would this be under print settings, filament, or printer?
Veröffentlicht : 27/01/2021 8:02 pm
- [...] I'll try to find a guide on how to do this. Would this be under print settings, filament, or printer?
Here's Prusa's procedure. There are many variations.
Veröffentlicht : 27/01/2021 8:09 pm
Go for the last layers to 0.15 or 0.1.
Lower extrusion multiplier.
Use more or less heat.
Of course use ironing, and ironing you could adjust settings, so it does only a little ironing.(adjust spacing and or speed of ironing).
And every filament will be different, and you need to adjust.
Veröffentlicht : 29/01/2021 9:26 pm
