This sound is driving me CRAZY
matthew.m63
(@matthew-m63)
Hello everyone! I got my MK3 a few months ago and LOVE IT!!!
Yesterday, when i got home i realized the printer crashed and stopped because the print lifted from the bed and dislodged.
Now, the printer is making a crazy vibration noise when printing. I attached video.
I touched the power supply, and other parts, and cannot seem to isolate where it is coming from.
Any ideas?
Link to video
Opublikowany : 12/02/2019 8:17 pm
Nikolai
(@nikolai)
Re: This sound is driving me CRAZY
Video is not available to me.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 12/02/2019 8:21 pm
matthew.m63
(@matthew-m63)
Here is another link in case anyone has trouble. Its getting louder every minute
https://drive.google.com/file/d/1px4LwkdP-ZTIb-XTM8TgPTbZqc8rD0zW/view?usp=sharing
Opublikowany : 12/02/2019 8:34 pm
Nikolai
(@nikolai)
So which of many sounds is driving you crazy? Diagonal movement?
Often linked posts:
Real Multi Material
Opublikowany : 12/02/2019 11:44 pm
ryanm
(@ryanm)
If you find a solution let me know, I'm having similar issues but came like this from the factory. Bearings are junk. I can't imagine the QA has always been this bad but it seems like many corners are being cut.
Opublikowany : 13/02/2019 12:05 am
If the printer actually jammed the extruder into the part and the part off the bed so it jammed the Y-Axis ... You may want to pop the bed off and check all the bearings are still snugged down and centered on their seats.
Opublikowany : 13/02/2019 2:03 am
matthew.m63
(@matthew-m63)
I will take apart the printer this weekend and re-assemble using modded bearing holders. I also bought some high end SKF bearings, i will let everyone know if it makes a difference on Monday.
I got a different surprise this morning when i woke up, and my brand new pei sheet peeled off.. and i used a LOT of windex. I guess its part of the hobby.. I emailed prusa, i hope they send me a replacement sheet. It was only 2 weeks old.
Opublikowany : 13/02/2019 10:40 am
After 2000 hours on oiled but ungreased bearings I replaced them with higher quality Misumi's (6 row instead of 4 row). Made a difference in stiction, pretty much unnoticeable everywhere else, including noise. But X and Y feel "tighter" in a good way; and less rotational play on the table.
PETG and PEI; I'm guessing you didn't read all the posts about how to prep the sheet before printing large PET pieces. PET damage to PEI is a long time known issue - there are many posts discussing ways to limit the adhesion. Windex - when applied properly - is only one way.
Also - your PEI sheet looks like you've been using sand paper on it?
Opublikowany : 14/02/2019 3:02 am
