This sound is driving me CRAZY
Hello everyone! I got my MK3 a few months ago and LOVE IT!!!
Yesterday, when i got home i realized the printer crashed and stopped because the print lifted from the bed and dislodged.
Now, the printer is making a crazy vibration noise when printing. I attached video.
I touched the power supply, and other parts, and cannot seem to isolate where it is coming from.
Any ideas?
Link to video
Re: This sound is driving me CRAZY
Video is not available to me.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Here is another link in case anyone has trouble. Its getting louder every minute
https://drive.google.com/file/d/1px4LwkdP-ZTIb-XTM8TgPTbZqc8rD0zW/view?usp=sharing
So which of many sounds is driving you crazy? Diagonal movement?
Often linked posts:
Real Multi Material
If you find a solution let me know, I'm having similar issues but came like this from the factory. Bearings are junk. I can't imagine the QA has always been this bad but it seems like many corners are being cut.
If the printer actually jammed the extruder into the part and the part off the bed so it jammed the Y-Axis ... You may want to pop the bed off and check all the bearings are still snugged down and centered on their seats.
I will take apart the printer this weekend and re-assemble using modded bearing holders. I also bought some high end SKF bearings, i will let everyone know if it makes a difference on Monday.
I got a different surprise this morning when i woke up, and my brand new pei sheet peeled off.. and i used a LOT of windex. I guess its part of the hobby.. I emailed prusa, i hope they send me a replacement sheet. It was only 2 weeks old.
After 2000 hours on oiled but ungreased bearings I replaced them with higher quality Misumi's (6 row instead of 4 row). Made a difference in stiction, pretty much unnoticeable everywhere else, including noise. But X and Y feel "tighter" in a good way; and less rotational play on the table.
PETG and PEI; I'm guessing you didn't read all the posts about how to prep the sheet before printing large PET pieces. PET damage to PEI is a long time known issue - there are many posts discussing ways to limit the adhesion. Windex - when applied properly - is only one way.
Also - your PEI sheet looks like you've been using sand paper on it?
