The print layers are shifted to the left
Hello guys, first of all excuse my english, it's not my native language.
I just finished my first 3D print, and I (already) have a problem.
The print layers are shifted to the left.
what is the cause of this problem?  😳
Re: The print layers are shifted to the left
can you just print that but only the first layer?
off hand looks like your Z should be closer to the build plate
or print that. so we can see it
That's the first layer
i'll do it right now
let it fill the first layer, sorry I should have said it better
Here are the files, thank you fo you help
raise your "live z" number. where is it now?
well, raise the negative of you live Z... it's an odd setting.
it's actually at - 0.410
try -.700
then go in steps of 50 when it gets close
I forgot to ask, is that the batman from the SD card Gcode?
So, the live Z axis is set to -0.700
Yes it's the original from the SD card
is your X belt tight? looks like first layer shifted
your Z looks better.
here is a 1 layer sheet from my setup.
red circle is too high Z
green is about correct
blue is too low.
hope you figure out your shift now.
Okay undestood, yeah my Z axis looks like your
Well i think it's not. Confirm it and i'll try to fix it
hard to tell.
hopefully your belt isn't maxed out but you should be able to tighten it at the motor
I gotta get some sleep good luck
Thank you, i'll try to fix this and tell you if it fix my problem
Good night from France  😀
You fixed it man my belt wasn't tighten at all
nice, glad to hear it.
