The print layers are shifted to the left
bellaiche.w2
(@bellaiche-w2)
Hello guys, first of all excuse my english, it's not my native language.
I just finished my first 3D print, and I (already) have a problem.
The print layers are shifted to the left.
what is the cause of this problem? 😳
Posted : 08/12/2018 12:36 pm
toaf
 toaf
(@toaf)
Re: The print layers are shifted to the left
can you just print that but only the first layer?
off hand looks like your Z should be closer to the build plate
Posted : 08/12/2018 12:39 pm
toaf
 toaf
(@toaf)
or print that. so we can see it
Posted : 08/12/2018 12:47 pm
bellaiche.w2
(@bellaiche-w2)
That's the first layer
i'll do it right now
Posted : 08/12/2018 12:56 pm
toaf
 toaf
(@toaf)
let it fill the first layer, sorry I should have said it better
Posted : 08/12/2018 1:07 pm
bellaiche.w2
(@bellaiche-w2)
Here are the files, thank you fo you help
Posted : 08/12/2018 1:25 pm
toaf
 toaf
(@toaf)
raise your "live z" number. where is it now?
Posted : 08/12/2018 1:29 pm
toaf
 toaf
(@toaf)
well, raise the negative of you live Z... it's an odd setting.
Posted : 08/12/2018 1:30 pm
bellaiche.w2
(@bellaiche-w2)
it's actually at - 0.410
Posted : 08/12/2018 1:40 pm
toaf
 toaf
(@toaf)
try -.700
then go in steps of 50 when it gets close
Posted : 08/12/2018 1:43 pm
toaf
 toaf
(@toaf)
I forgot to ask, is that the batman from the SD card Gcode?
Posted : 08/12/2018 1:51 pm
bellaiche.w2
(@bellaiche-w2)
So, the live Z axis is set to -0.700
Yes it's the original from the SD card
Posted : 08/12/2018 2:18 pm
toaf
 toaf
(@toaf)
is your X belt tight? looks like first layer shifted
your Z looks better.
Posted : 08/12/2018 2:22 pm
toaf
 toaf
(@toaf)
here is a 1 layer sheet from my setup.
red circle is too high Z
green is about correct
blue is too low.
hope you figure out your shift now.
Posted : 08/12/2018 2:30 pm
bellaiche.w2
(@bellaiche-w2)
Okay undestood, yeah my Z axis looks like your
Well i think it's not. Confirm it and i'll try to fix it
Posted : 08/12/2018 2:48 pm
toaf
 toaf
(@toaf)
hard to tell.
hopefully your belt isn't maxed out but you should be able to tighten it at the motor
I gotta get some sleep good luck
Posted : 08/12/2018 2:57 pm
bellaiche.w2
(@bellaiche-w2)
Thank you, i'll try to fix this and tell you if it fix my problem
Good night from France 😀
Posted : 08/12/2018 3:09 pm
bellaiche.w2
(@bellaiche-w2)
You fixed it man my belt wasn't tighten at all
Posted : 16/12/2018 10:36 pm
toaf
 toaf
(@toaf)
nice, glad to hear it.
Posted : 17/12/2018 2:32 am
