Temperature problem after changing the nozzle?
Hi there! I have successfully printed half of my Prusa PLA with 215C with the brass nozzle 🙂 after I have decided to print some carbon filament with the hard steel nozzle the temperature 215C is not enough for PLA not even 225, the layers don't stick to each other very well. Do you know what problem can be?
Thanks!
Veröffentlicht : 10/09/2018 11:38 pm
Re: Temperature problem after changing the nozzle?
try cleaning off the bed with soap and water. im guessing the hard steel nozzle is still in?
Veröffentlicht : 11/09/2018 6:04 am
Did you re-do your Live-Z calibration? It's a good idea after a nozzle swap, particularly if you use different brands of nozzles. I've only had to raise my temps ~5C with the hardened steel nozzles.
Veröffentlicht : 11/09/2018 6:36 am
