Superpinda keeps smacking print
CliffordTheRed
(@cliffordthered)
I just bought a Prusa MK3S+ used from someone and it works fine except the superpinda starts to smack into other parts of the print and ends up ruining the print. I am still relatively new and have no clue how to fix this or adjust the superpinda without messing something up. It is currently and nearly the EXACT same depth as the extruder nozzle, and my other printers have it a little higher up, noticeably so and it works fine with them.
Opublikowany : 19/03/2025 5:46 am
Eve
 Eve
(@eve)
RE: Superpinda keeps smacking print
I am still very new to  3D printing, but found the Prusa support page very helpful. Under https://help.prusa3d.com/guide/how-to-replace-a-p-i-n-d-a-sensor-mk3s_163386#163692 they describe how to adjust the sensor after replacing it. So if anything gets messed up, you can just follow the instructions there. There is a picture showing the correct height of the Pinda in comparison to the nozzle.
Opublikowany : 13/04/2025 2:14 pm
1 ludzie polubili
