Super Pinda broken?
Hello,
prusa i3 MK3s+
Ran g80 in Pronterface. Then g81.
Results greater than .2?
What should I do?
Z axis calibration hit everytime super pinda was raised even a bit, any lowering and I had z corrections around 3mm in first layer calibration
Thank you
RE: Super Pinda broken?
Also how do I contact Prusa support.
Preferably a phone number
@oliver-printer
Hello and welcome to the Prusaforum!
I don't quite understand the first question, and I can see almost nothing in the picture.
The best way is to contact Prusa via chat. Log in with your account at Prusa and select the eshop. After a few seconds, the chat window appears in the lower right corner. Deactivate adblocker. If the chat window does not open, try to change the browser (google chrome).
@oliver-printer
Can you confirm the sensor is working? Does a light come on if you put a tool just belwo the sensor?
