[Résolu] Struggling to understand what to do next
Steve Tarantola
(@steve-tarantola)
Membre
Hi all,
I thought I had successfully built, calibrated and completed the First Layer Adjustment. The Frist Layer Adj test looked good, solid, lines were barely visible but looked like the book.
I proceeded to do the Prusa_test_pattern_0.2mm_PLA_MK3S_25M ..No change to the Prusa file was made...the base seemed to print fine but the top of the letters are screwed up.
I am using Overture PLA 1.75mm +/0.03mm
Is my first layer not adjusted properly? too high? too low?
Any guidance to what to do would greatly be appreciated.
Publié : 24/10/2023 10:17 pm
Steve Tarantola
(@steve-tarantola)
Membre
RE: Struggling to understand what to do next
After redoing the pre-flight checks and wizard calibration a couple of times.........I am thinking I need to look at my x-axis belt. I knwo the attached image is not a good first layer but it shows that the x-axis stutters during movement.
I will have to figure out if I am to loose or too tight
Publié : 25/10/2023 3:55 pm
Check the grub screw's on your motor pulley
Publié : 25/10/2023 4:20 pm
Steve Tarantola
(@steve-tarantola)
Membre
Thank you Joan!!!!!
I would not have checked that first.
Publié : 25/10/2023 8:59 pm
