[Resuelto] Strange Vertical Lines on Flat Surfaces
Tarek Sobh
(@tarek-sobh)
Hello all!
I'm facing a weird issue of vertical lines showing up on smooth surfaces on printed parts. I noticed that this doesn't happen with complex shapes, but only on simple ones with somewhat flat surfaces. I'm not really sure what's causing this issue. Could it be a wrong Z calibration? Maybe it's setup too low and close to the print bed? I have 3 different MK3S printers and these lines are showing on all of them in somewhat the exact same places.
Best Answer by Peter M:
Has nothing to do with first layer.
Try different filament, en slower speed.
1 picture looks like linear advance
2 picture looks like seam.
Print a lot hotter, like 10 degrees, and test.
Nozzle partially clogged? Change nozzle then you now it within 10 minutes if this is the problem.
Respondido : 30/07/2021 12:04 pm
Peter M
(@peter-m)
Respondido : 30/07/2021 6:28 pm
1 les gusta
Those all appear (to me) to be your z-seam. You can minimize the appearance of the seam, but not eliminate it completely.
Respondido : 30/07/2021 6:32 pm
1 les gusta
Tarek Sobh
(@tarek-sobh)
Thanks
Thank you guys @peter-m and @bobstro .. I didn't know about this. I'll try reducing the speed and increasing the temperature as suggested and see if this would improve the prints.
Respondido : 31/07/2021 7:55 pm
