Strange layer shift
guillaume.lucas-garra
(@guillaume-lucas-garra)
Strange layer shift
Hi everyone !
I have a weird problem that popped up on my MK3S lately. ( It has the MMU2 on it but the problem, for once, doesn't seem related to it, si I post here).
I have this strange layer shift on almost all my prints. It does not look like a belt issue, as the shift dissapear progressively after a few layers. My bed sheet il also placed correctly. The shift often appears on the first centimeter of the print. It happens regardless of the filament I use..
It's hard to see here, but the shift is both on the X and Y axis.
Any Idea of what could be causing that ?
Edit : Sorry I just can't insert  that picture properly.
Best Answer by Neophyl:
With a step like that it looks like the grub screws on your motor pulleys are loose.  Its the single most common cause of layer shifts like that.  They must be tightened parallel to the flat on the shaft and its worth checking them regularly as part of maintenance checks.
Also what I do is once aligned and tightened properly is draw a line in sharpie marker on to the motor shaft and pully so that you can see if it ever moves as the line will be offset.
If its not the pulleys and it always happens at the same height then that would suggest a break in one of the wires to the motor(s).  Basically when the wires are in certain positions the break occurs.  Unfortunately that type is issue is very difficult to track down and needs something like a digital multi meter at minimum to check wire continuity.
Ce sujet a été modifié il y a 5 years 4 fois par guillaume.lucas-garra
Publié : 13/02/2020 2:31 pm
Knickohr
(@knickohr)
Membre Moderator
RE: Strange layer shift
Is it really a shift ?  It's shrinking. Show us the other side of the thing.
I suggest it is a cooling problem. You print the first few layers with less cooling because there is 100% infill and more layer printing time. And after that point your fan speeds up because of less layer printing time.
Please check.
Thomas
Publié : 14/02/2020 8:13 am
Publié : 14/02/2020 8:25 am
@knickohr
Tanks for your answer, it's true that on the picture it does look like shrinking, but I'm pretty sure it's not. Here's the full view of the part :
@neophyl
I'll check that right away, see if that's the source of the problem.
Publié : 17/02/2020 10:44 am
Knickohr
(@knickohr)
Membre Moderator
Yes correct, this is shifting, not shrinking 😉
Try neophyl solution.
Thomas
Publié : 17/02/2020 10:50 am
Thanks everyone !
One of my grub screw was indeed slighly loose, I tightened it and started printing again. So far, no shifting, so it seems that was the problem.
Guillaume
Publié : 18/02/2020 10:58 am
rmm200
(@rmm200)
Posted by: @guillaume-lucas-garra
Thanks everyone !
Guillaume
You have set yourself up to have it fail again...
Loosen both grub screws.
Align one with the flat - and fully tighten that one.
Finally, fully tighten the second grub screw.
On those screws, what you do and the order you do it in actually does matter.
Publié : 18/02/2020 3:58 pm
