steel sheet cover
Hi, I just assembled i3 MK3 printer. A steel sheet is covered by foils from both sides. Should I remove the foils before use it or keep it there? I have not found any help about that in the manual.
Respondido : 12/07/2018 4:10 pm
Re: steel sheet cover
Hello Pavel,
i guess that you mean the PEI sheet.
Just in case you are not joking, DON´T remove the PEI sheet !!!
Greetings
Kai
nec aspera terrent
Respondido : 12/07/2018 4:40 pm
