"some problem encountered z leveling enforced"
JL
 JL
(@jl)
Hi guys,
I have had my printer about a week and half and have been printing almost all day everyday since I got it.
I did not print the last 2 days, and now when I go to print something, It is not working anymore.
I get the message "some problem encountered z leveling enforced" and it seems like instead of starting in the front left corner it is trying to start over to the right a bit.
I re calibrated XYZ, and I now I can't even do the 1st layer calibration without getting this error.
Could somebody please help me out with this?
Thank you,
Jason
Postato : 17/05/2020 6:58 pm
RE: "some problem encountered z leveling enforced"
Is the printer on a solid flat surface? Vibration during mesh bed leveling can cause this.
Postato : 18/05/2020 1:16 pm
JL
 JL
(@jl)
@bobstro
Yes, it is currently sitting on a dresser, with a large top.
It is really heavy and does not really move, it is probably more stable then most tables.
Postato : 19/05/2020 2:57 pm
JL
 JL
(@jl)
It wound up being my X axis somehow lost access.
I went back through that part of the build and that fixed in.
Postato : 20/05/2020 12:41 am
WM3
 WM3
(@wm3)
Same issue here of entering a constant loop of "some problem encountered z leveling enforced". The cause was me catching a thread on the back registration post when replacing the steel sheet. Even through I corrected the placement; the software was stuck in the error loop whenever it measured the back right corner.
I tried re-flashing the firmware (3.10.0.4481). No improvement. Still locked into the "z level enforced" loop although the location changed from the back right corner to the middle front location.
Used the Calibration Wizard and reset the Z-Height. Ran the 3x3 Bed Level test print and everything is working again.
Postato : 30/08/2021 4:04 pm
2 persone hanno apprezzato
JulieL
(@juliel)
I suddenly got this issue. Ran the Calibration Wizard and everything worked normally after that.
Postato : 25/09/2022 9:52 pm
1 persone hanno apprezzato
