Some prints popping lose from print bed before completion
dimprov
(@dimprov)
It has happened using the Prusa PLA that came with the kit. Of course, once it happens, the print is quickly ruined.
How to prevent it from happening? I do clean the print bed with IPA (and let it dry off) before starting a new print.
Napsal : 28/04/2018 3:41 am
thrawn86
(@thrawn86)
Re: Some prints popping lose from print bed before completion
which slicer? you can try any of these which are available in any slicer
-double check your live-Z/nozzle clearance. the manual has a handy visual guide of what that should look like
-slow down first layer, try 50% of your print speed
-make your first layer hotter, try 5-10 extra
-make your first layer wider and taller
-turn off first layer fan, if it isn't already
-use a skirt/brim (zero offset, touching the part) with several loops
Napsal : 28/04/2018 7:03 am
RH_Dreambox
(@rh_dreambox)
Clean your bed with a mild soap solution and water, then you can use IPA.
IPA is good against greasy surfaces but not surfaces with water-soluble dirt.
Napsal : 30/04/2018 4:12 pm
dimprov
(@dimprov)
Using a brim solved this problem for me. 🙂
Napsal : 30/04/2018 5:01 pm
