[SOLVED] Extruder slipping from hotend jam
Timothy Graupmann
(@timothy-graupmann)
I've been having an issue with the filament slipping. If I unload the filament and put in a fresh tip that usually fixed the issue.
But now I can't seem to load the PLA grey filament. The stepper threads appear to be slipping.
https://photos.app.goo.gl/iK5xG1WtGWgQpauF2
What could it be?
Is it the spring screws?
I have the bondtech pulley with the lock screw nice and tight on the flat side of the motor.
My extruder motor isn't bad is it?
Thanks!
Veröffentlicht : 30/04/2018 12:57 am
Timothy Graupmann
Re: Extruder slipping
I think my hotend is jammed. I'm going to try a high temp and use a needle to clean out the hotend.
The filament is being fed to the hole. I think it's just the hole is jammed and it's giving the motor enough resistance that it skips.
Veröffentlicht : 30/04/2018 3:26 am
Timothy Graupmann
This is probably a bad idea, but what if I touched a soldering iron tip to the plastic at the top of the hole?
I probably need to remove the hotend and clear whatever gunk made it down into the hole...
Veröffentlicht : 30/04/2018 9:07 am
Timothy Graupmann
This looks like the problem. There's some filament stuck near the end of the E3D hotend tube.
Veröffentlicht : 30/04/2018 9:57 am
Timothy Graupmann
I used my soldering iron with the pointy tip to make a hole in the blockage and used the hex key to grab the stuck filament in the tube.
Veröffentlicht : 30/04/2018 6:50 pm
Erik
 Erik
(@erik-3)
Re: [SOLVED] Extruder slipping from hotend jam
That was a roller coaster. I'm glad you got it figured out.
Veröffentlicht : 30/04/2018 10:04 pm
Timothy Graupmann
It turns out that I also have to replace the hotend tube. I can't do a full print without some slipping which you can see the tip of the tube is slightly bent. The result is I get gaps in the print which causes the final print to break apart too easily.
https://www.amazon.com/gp/product/B01CUPV9KC
Veröffentlicht : 01/05/2018 5:01 pm
Timothy Graupmann
I pulled out the tube with the plyers.
And then cut some tube at the same length on a breadboard.
The replacement tube reinserted easily.
Veröffentlicht : 02/05/2018 11:42 pm
Timothy Graupmann
[Need Support] Frequent Filament Jams
I've been dealing with frequent filament jams several times a day. I can get a jam unloading filament, where the blob can usually be removed via the extuder door with some wire cutters. The jams going the other way are more involved. The fans have to be removed with the cover and the hotbrick. The tube can be removed easy enough to push out whatever blob is stuck. The process takes about 5 minutes to clean and reassemble but it's a major PITA.
I'm printing with pronterface with PLA. I did notice that printing with USB connected the temp is set to 210C. The preheat menu for PLA uses 215F. Is there a pronterface update that includes the option for MK3 with the higher temp?
Should filament jams be happening so frequently?
Veröffentlicht : 07/05/2018 6:38 pm
