Small Space at the Bottom of the Print
bunjeeb
(@bunjeeb)
I assembled the printer one week ago and realized that I have a small issue that sometimes prevents me to prevent some small detailed models. Please check the image below. Why do I have this small space on the left? It happens to me in many prints before also. May you please help.
Best Answer by Neophyl:
That can also be caused by improperly tensioned belts.
Postato : 12/11/2021 12:26 am
Utenti
RE: Small Space at the Bottom of the Print
It is either under extrusion or you are not low enough.  Both the bottom side of the print.
Postato : 12/11/2021 12:51 am
Postato : 12/11/2021 6:09 am
bunjeeb
(@bunjeeb)
should I tighten the belt more?
Also, the screws on the pulley was not 100% tightened
Postato : 12/11/2021 9:14 am
You could try setting your Z calibration a little lower, a bit more squish might help.
If you have prusament PETG download and print:
         https://www.prusaprinters.org/prints/46639-tension-meter-for-the-gt2-belts-of-i3-mk3s-or-prus
It MUST be prusament PETG or the reading will be off.
Postato : 12/11/2021 12:44 pm
1 persone hanno apprezzato
Loose screws can do the same as loose belts sometimes.
Postato : 12/11/2021 1:33 pm
bunjeeb
(@bunjeeb)
It was the Y Axis … this is the results after tightening the belt and the pulley screws
https://youtube.com/shorts/ws1FSG7O8Gs?feature=share
Questo post è stato modificato 4 years fa da bunjeeb
Postato : 12/11/2021 2:11 pm
bunjeeb
(@bunjeeb)
Fixed. Before and After tightening Y-Axis Belt and the pulley screws.
After Fixing Y Axis
Postato : 12/11/2021 3:19 pm
