Slightly misaligned layers
I wasn't happy with the supports prusaslicer generated, so I began using Cura recently. I'm noticing the layers are misaligned a little. It is easy to see in the picture, most notably on the right side. I have the outer wall set to 30mm/s, jerk at 8 and acceleration at 700 for the outer perimeter. I'm not sure what else to mess with without lowering the outer perimeter speed to a crawl.
Any idea on what to play with to refine this issue a bit?
Opublikowany : 11/03/2020 9:23 am
