sensor filamento
el sensor de filamento de mi mk3s no funciona, tengo que introducir el filamento manualmente, pero si toco los cables y saco un poco la ficha , si va, porque? estara el cable roto? o tengo que cambiar algo?
Napsal : 10/11/2021 7:12 am
Control panel
You can turn off the filament sensor and auto-filament loading in the control panel settings area. Once you do that your filament sensor won't be used, and you will have to use the control panel to unload and load filament. Cutting filament during a print to perform a color change will no longer work, and if your spools run out during a print, the printer will no longer stop to wait for more filament.
Napsal : 10/11/2021 1:11 pm
