Selfttest error: Please check/ Not connected - Heater/Thermistor
rakhmetov
(@rakhmetov)
Hi there,
I've assembled my new MK3S+ kit and can't get past the 'Heter/Thermistor' error during the selftest. It keeps failing while attempting to warm up the heat bed.
What did I try so far?
  • Used a hair dryer on the bed and extruder while the printer was on -> The LCD screen displays a rise in temperature for both.
    • I assume this means that both thermistors work correctly. Could anyone confirm? There isn't anything else that would react to temp changes except for thermistors(and display it on the LCD screen :thinking:) ??
I followed this guide https://help.prusa3d.com/article/multimeter-usage_2117 .
  • the Einsy heat bed power shows zero voltage (measured against the screws on Einsy board, the two most to the right),
  • the 2 PSU power connections display 23-24ish voltage.
So, being a complete electronics noob, it looks like there is no voltage to the heat bead at all. I'm stuck now as how to proceed and troubleshoot. Do I need a new Einsy board, change the screws, fiddle with the cables? Does anyone have tips for me?
Publié : 02/10/2022 5:59 pm
RE: Selfttest error: Please check/ Not connected - Heater/Thermistor
have you checked the three fuses?
Publié : 02/10/2022 6:17 pm
rakhmetov
(@rakhmetov)
Hey
I've tested all three fuses for continuity. All seem to work.
Publié : 03/10/2022 6:12 pm
I would report this to Prusa! Just log in with your Prusa account and select the eshop. After a few seconds the chat window should appear on the lower right corner. If the chat window does not open, disable a possibly activated adblocker or try another browser.
wbr,
Karl
Publié : 03/10/2022 9:22 pm
rakhmetov
(@rakhmetov)
Hey,
Thanks, will try to clarify with support directly. thx for help!
Publié : 04/10/2022 2:29 pm
SoCalSteve
(@socalsteve)
I had the same issue. Getting a new thermistor.
Publié : 17/10/2022 9:54 am
