self test says: bed heating ................. for an hour
Ah
 Ah
(@ah-3)
Should this be.     the lcd screen says the temp on the heat bed is 109 but it is meant to be 60    I think.
Actual heat/target heat:       109 /60
the printer stops here in the self test.
AH
Opublikowany : 06/11/2020 8:16 pm
RE: self test says: bed heating ................. for an hour
Posted by: @annehext
AH
Can you be more specific about what you were trying to do? error messages?
Opublikowany : 06/11/2020 10:11 pm
Ah
 Ah
(@ah-3)
We have just finished building . Then we ran the self test from the lcd screen and it did some of the test and said congratulations it has perpendicular something then the nozzle heated up ok then it said bed heating and got stuck at
109/60
Opublikowany : 07/11/2020 12:06 am
@annehext
If the selftest test has passed without errors, everything should be ok. Try to heat up a filament in the filament settings to the preset temperature, e.g. PLA. After a few minutes both elements should have reached the preset temperature. If this does not work we have to start troubleshooting.
Opublikowany : 07/11/2020 1:11 am
