SD Card Included? - Found
KZ4YG
(@kz4yg)
Was I supposed to get a SD Card with the sample files?
If not where can I get them?
I just finished assembly, self test, XYZ calibration, first layer calibration and am trying to go to first print.
Publié : 01/01/2019 5:52 pm
Re: SD Card Included?
if you are on windows, check your Prusa tab on the start menu
or https://www.prusa3d.com/printable-3d-models/
Publié : 01/01/2019 6:39 pm
KZ4YG
(@kz4yg)
Thanks
Not on Windows but I found the SD Card, it was hiding in the LCD bag.
Now I'm fighting with tuning the first layer.
Publié : 01/01/2019 6:53 pm
KZ4YG
(@kz4yg)
Re: SD Card Included? - Found
Turns out you should really check the spare spool you are using to test with is actually PLA (works much better) the test spool I grabbed was ABS soI was probably lucky it extruded at all with PLA settings. DOH!
Using some actual PLA the first layer is going down nicely and staying down. Impressed so far with how easy setup has been compared to other printers I've used.
Publié : 01/01/2019 7:58 pm
Mustrum Ridcully
(@mustrum-ridcully-2)
on mac OS look in your applications folder for the folder Original Prusa Drivers
it has distinctive icon
Publié : 01/01/2019 8:00 pm
