Screws on X-carriage-back dont byte anything
3Dsolid
(@3dsolid)
Hi guys, middle and  2  bottom  screws on back of X carriage don't bite anything . What I miss in assembly?
I  refer on step 43 in  assembly steps.
Tnx
Opublikowany : 13/08/2019 6:08 am
RE: Screws on X-carriage-back dont byte anything
There are only 12 steps on assembling the x axis.  Do you mean assembling the extruder ? If so isnt step 43 inserting 2 zip ties ?
Anyway from your description you have probably missed inserting the M3 nuts into the Extruder back, these are what the X carriage screws thread into.  Its Step 16 on E Axis assembly https://manual.prusa3d.com/Guide/5.+E-axis+assembly/1055?lang=en
Opublikowany : 13/08/2019 6:43 am
3Dsolid
(@3dsolid)
Sory, step 43 Mounting  the X-carriage back in (5. E-axies assembly (spiral wrap))
https://manual.prusa3d.com/Guide/5.+E-axis+assembly+(spiral+wrap)/510?lang=en#s8213&_ga=2.56771951.472951785.1565674154-107903044.1555323110
Opublikowany : 13/08/2019 7:11 am
As I said check out Step 16, picture number 2, where you insert square nuts into the X-Carriage assembly.  These nuts are what the x-carriage back screw into.
https://d17kynu4zpq5hy.cloudfront.net/igi/prusa3d/ME3cIhIZUt3E6uyu.medium
Opublikowany : 13/08/2019 7:58 am
Ive just realised we are referencing 2 different build guides .  I was using the MK3S build guide and you the MK3 guide.  Which printer are you trying to assemble ?
If using the Mk3 v3.06 guide that you linked to above you want X Axis assembly step 11 x carriage preparation.  That shows inserting the square nuts.
Opublikowany : 13/08/2019 8:04 am
3Dsolid
(@3dsolid)
I see now where I was make mistake. I 'm using MK3 model.
Tnx for help.
This post was modified 7 years temu by 3Dsolid
Opublikowany : 13/08/2019 8:15 am
I was going to mention the MK3 vs MK3S issue - it would explain using the wrong screws for the job.
Opublikowany : 13/08/2019 9:15 am
3Dsolid
(@3dsolid)
yes, maybe I use wrong  screws..must check it
Opublikowany : 13/08/2019 9:58 am
