retraction test and zxy cube
Gabik87
(@gabik87)
Dear all,
how can I improve the cube since there are burrs in the corners it is imperfect
and how can I remove or improve the wires in the object for retraction test?
Thanks
Thank you
Best Answer by bobstro:
Posted by: @luperto-gabriele
@bobstro
Dear, where should i fix these settings?
Well, I'm on a tiny phone now, so can't provide links to everything. Start googling those terms with "Prusa Mk3" and you should find enough info to get started. I've got a bunch of relevant info in the pages linked to in my signature below.
Opublikowany : 13/10/2019 6:45 pm
RE: retraction test and zxy cube
  • Slow down external perimeter speeds.
  • Add an external perimeter.
  • Calibrate Linear Advance for that filament (improves corners).
  • Calibrate Extrusion Multiplier for that filament (reduces unevenness due to over-extrusion and helps with stringing.)
  • Print cooler (helps with stringing).
Opublikowany : 13/10/2019 7:25 pm
1 ludzie polubili
Gabik87
(@gabik87)
@bobstro
Opublikowany : 13/10/2019 9:13 pm
@bobstro
Opublikowany : 13/10/2019 9:56 pm
Gabik87
(@gabik87)
@bobstro
I will read your link carefully.
Thank you very much
Opublikowany : 14/10/2019 7:28 am
Gabik87
(@gabik87)
@bobstro
Thank you very much
rmm200
(@rmm200)
Don't get your expectations too high either. This is FDM printing.
Look at your Prusa control box. The recessed letters for Prusa are about as good as you are likely to get.
A heat gun, applied judiciously, is great for removing hairs from your object.
Opublikowany : 14/10/2019 3:36 pm
1 ludzie polubili
Gabik87
(@gabik87)
@robert-rmm200
So, you mean that it's possible to adjust something, but it's remain a always fdm printing.
But I want to reach and understand and also manage with experience and so on this printer.
It's difficult now for me to know why my printer doing errors.
because anyway I see some beautiful prints on the web.
Thanks robert
Opublikowany : 14/10/2019 8:42 pm
