Replaced Nozzle
scott.w13
(@scott-w13)
Replaced Nozzle
The other day I had to replace the entire hot end; nozzle, block, et al. unfortunately have been banging my head against the wall trying to get this thing calibrated again. Just trying to print something wires them to slow down a lot otherwise it begins to skip lines on infill. Right now running at 1500mm/m with infill at 60% and 1st layer at 25%. Here is the result of such print Attached
Scott
Postato : 02/06/2018 6:01 pm
Re: Replaced Nozzle
you need to re do your Live Z adjustment.your nozzle seems way too high!
Postato : 02/06/2018 6:06 pm
scott.w13
(@scott-w13)
Re: Replaced Nozzle
in your experience, what kind of offset for PETG? I've seen a reference as much as .2 mm
Postato : 02/06/2018 6:43 pm
Re: Replaced Nozzle
Hi Scott,
every printer is different,
I can't say as I have the same offset for PLA and PETG on my printers.
regards joan
Postato : 02/06/2018 10:01 pm
JMcK
 JMcK
(@jmck)
Re: Replaced Nozzle
A nozzle height of 0.2 (or 1/2 the nozzle width) sounds right to what I recall reading.
Nozzle height and “Live Z” are related but technically different. Nozzle height is an absolute measure, live z is relative to your printer. My understanding of Prusa design may be a bit lacking here, but I believe the Live Z says how far above the point at which the PINDA fires to start printing. (You usually have a negative value for Live Z so it’s really “below”)
So a lot goes into that Live Z, there are tolerances on when the probe fires, and everyone mounts the thing a bit differently and physical tolerances of the various extruder parts, but essentially you’re looking for the live z value that gives you the desired nozzle height. I’m not near the printer today, but IIRC my live Z is -0.607, it I’d be willing to bet that’s the wrong number for you.
Reread and re-run the live z calibration as was said earlier. The new nozzle needs a new value.
When someone asks you if you're a god, you say, "YES!"
Postato : 02/06/2018 11:55 pm
rob.l6
(@rob-l6)
Re: Replaced Nozzle
Just a little bit higher for PETG than for PLA, but there isn't much in it, is my experience.
Postato : 03/06/2018 6:58 am
