[Solved] « Regular » layer X axis shift
PapaYankee
(@papayankee)
Hello,
I assembled my MK3 with some trouble, but nothing unbearable. The first prints went wonderfully okay.
And then, more often than not, I get a weird but (almost) systematic layer shift on the X axis, around 5mm height (the two objects on the photos are laying flat, but are printed vertically ; each photo shows only one side - left side of first object, right side of second object). This shift is sooo regular that, when two objects are put side to side, there is an almost perfect match (third photo).
Any idea what may cause this ?
Posted : 08/02/2022 9:55 pm
PapaYankee
(@papayankee)
RE: « Regular » layer X axis shift
I did print a calibration cube (20x20x20). The flaw is quite visible. Surprisingly enough, because I had not seen this before, it appears twice (bottom and top).
Any idea how to correct this ?
Posted : 09/02/2022 8:24 pm
Bob
 Bob
(@bob-2)
Slicer?
Cheers
-Bob
Posted : 10/02/2022 7:56 pm
PapaYankee
(@papayankee)
Using Prusa Slicer, latest release.
Several tests on the machine have led me to focus on the X stepper motor, which clearly « blocks » sometimes.
Posted : 10/02/2022 8:08 pm
Bob
 Bob
(@bob-2)
What do you mean by blocks?
Cheers
-Bob
Posted : 10/02/2022 8:23 pm
PapaYankee
(@papayankee)
@Bob
Printer powered off, x-belt removed, x-axis motor unscrewed from its orange holder. When slowly turning the pulley, resistance is not constant. Usually pulley turns ok (small resistance). After one turn and a half (more or less) resistance suddenly becomes far stronger, need more force to overcome. Then gets back to normal, up to next time.
Posted : 10/02/2022 9:10 pm
Bob
 Bob
(@bob-2)
This sounds like a new printer, perhaps you should have a chat session with Prusa support, maybe you got a bad stepper that can be replaced under warranty.
Cheers
-Bob
Posted : 10/02/2022 9:22 pm
PapaYankee
(@papayankee)
@Bob
Yep, did send them some email. Waiting for an answer.
Posted : 10/02/2022 10:30 pm
Email is often slow.  For immediate support: Log into your Eshop account, navigate to Help and live chat is at bottom right in most browsers. If not you may need to disable your ad-blocker temporarily.
Posted : 10/02/2022 11:50 pm
