Received the wrong IR-Sensor in my MK3S upgrade kit
I was putting off installing this upgrade because of the printer being unusable until it went back together however I finally cleared space and time and got started. I just got to the step where I install the IR-Sensor and the one in the bag is the same as the one I pulled off the MK3 and does not fit the new assembly. Can I get the appropriate one shipped ASAP? I took a picture of both of them together if you'd like to see it. Order Reference 192234875 - placed on 02/22/2019
RE: Received the wrong IR-Sensor in my MK3S upgrade kit
This is the Prusa Forum, not Prusa customer support.
Contact Prusa via Email or (if you want the issue resolved fast) via livechat on their shop-page (need to be logged in for that, I believe)
But yeah, that doesn't look like the MK3S sensor but like the MK3 sensor.
I would also suggest to ask Admin to delete the order # from your post. This is a public forum and you don't want somebody messing around with it.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
