Quality issue between bottom and support
I've been noticing this reoccurring issue with my prints. All sides look fine except for the side in touch with the support. I've been using a raft. It doesn't make any sense. I even tried up-ing the bottom layers from 3 to 7. Same result. Am I missing something?
Thanks,
Tim
Postato : 29/12/2018 10:55 pm
Re: Quality issue between bottom and support
Printing on a raft does that, you're basically printing your first layer on an air gap otherwise the raft would become part of your print. Try without the raft and make sure your offset is properly set.
Postato : 29/12/2018 11:58 pm
