PrusaControl crash
Hello everyone,
this is my first post.
I have a problem with Prusa Control. I don't know why (I tried on other PCs, and the software works fine), but when I try to load a .stl model, the PrusaControl software immediately crashes. This problem doesn't happen when I try to load a .gcode file.
Do you have any idea about that? How I can overcome the problem?
Thanks,
Fabio.
Re: PrusaControl crash
is the .stl file a good size? I had mine crash on me if the modle was say way too big. once I went in and fixed the size it all seem good
Same Issue for me. PrusaControl (0.9.4_415_beta) hangs as soon as i "File" - "Import Model File" - Choose a (small) stl file
Sometimes I see the STL on the model base in the UI, sometimes not, it hangs immediately after loading the model.
Tried different stl models from thingiverse (they work fine in Slic3r Prusa Edition, So i will use that for now.
Thx,
Sean
