PRUSA squeaks - like a mouse 🙂
GTRAIN
(@gtrain)
hello  - problem with i3mk2s +.
Printer bought, assembled by yourself. During printing, with quick turns, XY squeaks - like a mouse 🙂
anyone knows what could be wrong?
tnx!
Opublikowany : 01/05/2021 7:32 am
Clarmrrsn
(@clarmrrsn)
RE: PRUSA squeaks - like a mouse 🙂
If this is an issue (Difficult to say without hearing it, maybe upload a video)
Belt on X rubbing on End caps, check it has clearance and is running straight?
Check Pulleys on X and Y have clearance between pulley and motor, check the idler pulley screws are not too tight? (Idler must be able to spin freely)
Doesn't sound like it could be a bearing issue, but did you grease them before assembly?
Tank you very much!
Opublikowany : 01/05/2021 8:57 am
GTRAIN
(@gtrain)
@clarmrrsn
Tnx. I this moment its no problem.
shares for the answer. I think I know what happened. the table belt rubs against the bearing. about the structure of the placenta. I tweaked the setting and it's great!
Opublikowany : 01/05/2021 10:03 am
ssill2
(@ssill2)
@gtrain
I'm assuming this noise is coming from extruder?  I had something like this on negative movements on X axis.  It ended up being a screw overtightened.  check screws on the extruder.
Opublikowany : 01/05/2021 8:50 pm
GTRAIN
(@gtrain)
no, no, everything is already OK - the table drive belt was rubbing against the bearing - it's already OK, thank you for your interest
Opublikowany : 02/05/2021 9:54 pm
