Prusa i3 Mk3 Help Required
ashish.g
(@ashish-g)
first of all the web manual is tremendous. It has high high-quality pictures and could be very thorough. i'd suggest analyzing the step first after which move back and doing it. often i might observe the snap shots and no longer study and make a mistake. The best printer i've ever used is a Maker select 3-D with most of the mods accomplished. With that being my most effective frame of reference i was impressed with print best of the elements coming from Prusa to collect to MK3. universal the build took round eight hours and i struggled with some steps. specifically getting one screw in right here or there, or no longer reading the instructions efficiently and having to move back. I would like to factor out that the new spool holder is hard to put on and i ended up snapping and breaking it. again, I did no longer examine the guidelines for a way they said to put it on, however I accept as true with I did it the same way the outlined inside the instructions. true issue i will print another.
after I first fired it up and ran the self-test it'd no longer permit me maintain to due there being a Y-axis length discrepancy. i used to be impressed on how unique the self-take a look at is. The filament loading and unloading is likewise lots cooler than I in the beginning concept it to be. With my Maker pick, i'd have a number of problems on changing filaments and would ought to take the fan off to manual the filament in. One closing factor is, is this printer is quiet! The Maker select used to squeal to in which you could pay attention with the room's door closed. With the Noctua fan at the Mk3, you can positioned your ear subsequent to it and no longer listen it. The steppers and bearings still make a bit noise whilst shifting, however it's miles an awful lot greater enjoyable to be round.
i haven't had time to calibrate the Z-axis and get a smooth first layer however i can try that this night. For now i'll go away you with
Publié : 16/10/2018 1:20 pm
ashish.g
(@ashish-g)
Re: Prusa i3 Mk3 Review
Any Updates Guys !!!!!
Edited by admin: Don't quote the previous post. Thanks
Publié : 17/10/2018 3:58 pm
Hi Ashish,
This thread is entitled 'Prusa i3 Mk3 Review'
Are you having problems?
Regards Joan
Publié : 17/10/2018 4:11 pm
