Problem with the (first) layer(s)
AriZZ
(@arizz)
Hi Guys,
i got problems to get prints to function properly.
So I did the whole calibration and adjusted the nozzle hight on the z axes with multiple prints to check on. (again)
Also i checked the sensor for the right hight.
I have the bedcheck on the highest level now. (7x7 etc.)
I still got the problem, that the layer is scaring and sometimes not holding properly.
Attached you can find the last two prints, where i printed the calibration file. ( Bed level test )
After the first one i cleaned the plate again with alcohol after cleaning it with water in step one and alcohol in step two for the first calibration.
I dont know what the issue exactly is at the moment.
Do i have to level the bad on the left side for example (where it teared), or is it something else? If so, down or up? It looks way different from the standard issue with first layer lines.
Thank you very much in advance for any help you can give me and happy printing.
I s
Opublikowany : 06/02/2024 6:57 pm
