problem with printing
julian.z2
(@julian-z2)
It is not my first print, but after 2 weeks of not printing my every print is very bad. You can see the picture. Thanks for help.
Respondido : 21/08/2018 1:03 pm
RufusClupea
(@rufusclupea)
Re: problem with printing
Last time I saw something like that, it was because a large "booger" (joan.t calls them blobs of doom) had congealed on my nozzle/print head.
You may have a clogged nozzle. When the hot plastic begins to flow, does it come straight down, or at an angle or kinked?
That's "MISTER Old Fart" to you!
Respondido : 21/08/2018 4:15 pm
julian.z2
(@julian-z2)
Cant see how it goes, after 20 seconds something like this happen 😕 Anything left on the platform...
Respondido : 21/08/2018 4:39 pm
RH_Dreambox
(@rh_dreambox)
You have to adjust the Z.-level, lower the nozzle.
Respondido : 21/08/2018 6:06 pm
julian.z2
(@julian-z2)
So should i go more on minus or less? I was combining with this and problem was still happening.
Respondido : 21/08/2018 7:18 pm
RH_Dreambox
(@rh_dreambox)
You should go more minus. Try in step of -10 units so you don't jump over the best level.
Respondido : 22/08/2018 9:19 am
julian.z2
(@julian-z2)
I have gone -0.10 then again and again.... Still nozzle "catches" filament and destroys everything... I think it gives too much filament when it starts the line
Respondido : 22/08/2018 7:58 pm
The suggestions on Live-Z adjustment are good, but don't forget to give the bed a good cleaning. Touching the bed should be avoided. Give it a good clean with dish soap under the sink, then avoid touching it as much as possible. Give it a good wipe with 91%+ isopropyl alcohol whenever you do touch it. Do your Live-Z adjustments on a bed you're sure is clean!
Respondido : 23/08/2018 1:11 am
julian.z2
(@julian-z2)
I use 70% isopropanol before every print
Respondido : 23/08/2018 8:56 pm
Lichtjaeger
(@lichtjaeger)
This is the mistake. The remaining 30% will act as a separator. Use 95% IPA or higher.
Use soapy water to remove the contamination you added to the build plate.
Respondido : 24/08/2018 8:10 am
julian.z2
(@julian-z2)
Thank you, but you think that is the problem?
Respondido : 24/08/2018 11:34 pm
