Problem with calibration of Z axis (extruder touches the plate)
tshonka
(@tshonka)
Ok,
I am running the callibration and I get the following problem.
It starts at the left corner and the extruder hovers around 5 mm above the plate. Think that was is intended. Then after one minute it lower and it touches the paper (and plate) and it scratches the bed.
I have check the PINDA probe (like mentioned on the site) and did the test of the 0-1 and everything is ok.
I checked the setup of the extruder, everything seems to be in order also.
I checked the site with all things that could be wrong and everything seems ok.
Does anyone know what could cause the problem and how to solve it?
Respondido : 26/09/2019 11:10 am
rmm200
(@rmm200)
RE: Problem with calibration of Z axis (extruder touches the plate)
Verify Chapter 9 Preflight Check step 3. Make sure PINDA height is set correctly. Use ziptie for thickness.
Look at last picture on Step 3 and compare to yours.
Esta publicación ha sido modificada el hace 7 years por rmm200
Respondido : 26/09/2019 4:43 pm
