Problem with 1st layer calibration
Adam
 Adam
(@adam-3)
 I am hoping someone will know why my printer has started to do this.(see photo)
I had an issue with some jammed filament, which I sorted out, recalibrated and then started printing again, then all of a sudden, mid way through a print the nozzle lifted to 10cm off the bed and stopped extruding,
So I recalibrated the Pinda with the zip tie, then went through the calibration wizard, and it was all fine and reset.
NNowthough when I print the 1st layer calibration it does what is in the photo.
Anyone got an idea why?
Regards.
Respondido : 01/07/2023 12:01 pm
Give the print-sheet a really thorough clean, dishwashing detergent and HOT water; then try again.
Respondido : 01/07/2023 10:10 pm
GreggF
(@greggf)
Miembro
RE: Problem with 1st layer calibration
Hi Guys, I an experiencing exactly the same problem except my nozzle only lifted about 1 mm off the surface. The end result looks exactly like your photo. HELP?
Respondido : 02/07/2023 6:02 am
Please run a first layer Z calibration and show us the result *on the print sheet*
Respondido : 03/07/2023 1:12 am
