RE: Problem print quality Z-axis
The x and y axis you mean?
Check the whole printer on loose bolts and screws.
Check belts if they are to loose, a to tight belt is not good. All above is to get rid of mechanical problems.
It could be the stl model, print thicker, more wall thickness.
Is where model has mistake, what is in the inside of model?
Search forum on bulge.
Veröffentlicht : 15/02/2021 11:20 am
