[Resuelto] Printer Z offset for purge wipe offset is 1mm too tall
MadHatterMikie
(@madhattermikie)
Miembro
I have recently upgraded my MK3S to a MK3S+ it was working before however I got a jam in my hot end assembly so I figured I would do the upgrade I had laying around. after the upgrade the XYZ calibration goes off without a hitch or so it seems. I have adjusted the new PINDA sensor twice using the method in the instructions i.e. small zip tie. when i go to do the first layer calibration it purges what looks like 1mm too tall. is there any way to fix this?
Best Answer by FoxRun3D:
The superpinda triggers higher than the old pinda. Best distance is about 1.5mm.  I made this little gadget to help find the best distance: https://www.printables.com/model/57192 (of course you need a working printer to print it ☹️). You want to try stacking two zip ties.
Respondido : 09/01/2024 4:15 am
RE: Printer Z offset for purge wipe offset is 1mm too tall
Respondido : 09/01/2024 12:27 pm
MadHatterMikie
(@madhattermikie)
Miembro
Thank you so much i tried the fix this morning and it helped a lot!! I have a second printer and was able to print the part for the adjustment. I appreciate the help I was spinning my gears for a few days before I posted.
Respondido : 09/01/2024 5:26 pm
