Printer stuck on setup process
Ken A
(@ken-a)
When I first turned it on there was the language question.  I selected English, The "Original Prusa i3" display came up, then it went back to the language question. I selected English 3 or 4 times and it kept simply returning to that question.  I went to grab my computer and when I came back it is now at a different question.  The setup process question, where I answer Yes or No if I want it to "guide" me through the process.  No matter whether I hit yes or no, it goes to the "Original Prusa i3" display screen, then returns right back to the setup process question.
When I hit select Yes or No, it sounds like something is starting up (sounds like a hard drive spinning up) for a few seconds, then it stops.  There is no movement of any kind from the machine.
I've tried turning the machine off and on again, same problem, although the language question no longer comes up.
Best Answer by sylviatrilling:
It sounds like you might be hitting the reset button (marked with the 'X') instead of entering your selection by pressing down on the round knob.
Postato : 21/03/2022 2:20 am
sylviatrilling
(@sylviatrilling)
RE: Printer stuck on setup process
Mk3S+,SL1S
Postato : 21/03/2022 2:24 am
1 persone hanno apprezzato
Ken A
(@ken-a)
hahahaha.........yep! I was wondering why it was such an annoying button to hit depending on where the dial is pointing.
I actually finished assembly almost 2 months ago but have been busy and hadn't even tried turning it on yet, that's my excuse for not knowing the dial was also a button 🙂
Postato : 21/03/2022 2:26 am
