[Risolto] Printer stops before the start
Satzende
(@satzende)
Hello
I have a Prusa MK3 with mmu2. If I want to print something, the printer restarts after doing the 9 point test.
Firmware: prusa3d_fw_MK3S_3_7_2_2363.hex and for mmu2 = prusa3d_fw_MMU2board_1_0_5.hex
First Layer test = ok
selfest = everything OK.
Pronterface Console:
NORMAL MODE: Percent done: 0; print time remaining in minutes: 21
SILENT MODE: Percent done: 0; print time remaining in minutes: 21
fsensor_stop_and_save_print
echo: Enqueing to the front: "PRUSA fsensor_recover"
begin
echo: 3.7.2-2363
echo: Last Updated: Jun 27 2019 17:35:17 | Author: (none, default config)
Compiled: Jun 27 2019
echo: Free Memory: 2021 PlannerBufferBytes: 1392
echo: Stored settings retrieved
adc_init
CrashDetect ENABLED!
FSensor ENABLED
echo: SD card ok
echo: Unknown command: "105" (2)
Error: Line Number is not Last Line Number + 1, Last Line: 0
[ERROR] Error: Line Number is not Last Line Number + 1, Last Line: 0
Best Answer by Satzende:
Problem solved.
What exactly the problem was true is unclear.
What has been changed :
When installing Prusa Slicer you can choose the version of the printer. As a standard there is already selected one (which I have overlooked). When you set it up again, the standart selection was disabled, and my version was activated.
Then re-load the firmware on printers and mmu2s.
The printer is now working.
Postato : 13/08/2019 5:48 pm
Satzende
(@satzende)
RE: Printer stops before the start
Problem solved.
Postato : 19/08/2019 5:22 am
