Printer force me to take out and in the filament before the print, why?
kurt _hectic
(@kurt-_hectic)
Heja,
I hope that will be an easy one:
What I had, and what I want:
Preheating
Bed leveling
Sample line
1st later print
Printing the test of the model
What I have, dunno why:
Preheating
Bed leveling
Sample line
Extruder goes to the side, and I'm asked to take out and in the filament, which completely destroy the:
1st later print
Halp!
Napsal : 08/11/2023 1:50 pm
Robin_13
(@robin_13)
RE: Printer force me to take out and in the filament before the print, why?
Almost sounds like you have an issue with the setting of the filament being loaded and what the printer thinks it should be using.  Do the test files on the SD card work?
If the samples on the SD card that came with the printer works, then it may be related to your print file.  If you can save the project file and zip it, then upload it for someone to look at the model and code.
Napsal : 09/11/2023 10:26 pm
Two possibilities: as @robin_13 suggests you may have a change filament instruction in the gcode; if you haven't edited the start code the two possibilities are that the code was sliced for an MMU, or that you clicked on the slider in the slicer and forced a colour change.
Or: Your filament sensor is faulty - perhaps just a loose plug, possibly a broken connector - to test disable the filament sensor temporarily  (LCD menu) - if the print runs OK look there ... you can run OK without the sensor but you lose the run-out detection.
Napsal : 10/11/2023 12:21 am
kurt _hectic
(@kurt-_hectic)
Thank you. I disabled the sensor and now it's ok. When I'll find out what was the reason, I'll come back to write it down.
Napsal : 10/11/2023 6:59 am
