printer fails to print from sd card
having finished assembly and calibration, we proceeded to the included sd card to attempt a test print. after several starts (on several different models) all of which ended after the initial test informing us we needed to change filament as the color was wrong. at which time the process ended.
Respondido : 05/09/2019 5:59 pm
RE: printer fails to print from sd card
Turn off the filament sensor ... and search the Prusa blogs. This is a known issue with a sensor that isn't working properly.
Respondido : 05/09/2019 6:17 pm
