Printer Crash During Build - Y-axis will not pass self test - New MK3S Kit w/ no previous issues
Andy Ruth
(@andy-ruth)
Hello,
I have assembled my printer within the last few days and printed a couple test parts (PRUSA logo, Batman, etc.) and I printed a couple sets of US Covid 19 faceshield head bands. Last night I started another print and it crashed about 1 hour into the build. This was my first time running one of the "stacked" 4 piece headband files that is available to users.
My Y axis crashed and I cannot get it back to normal even after several resets/reboots. I attempted the self test again and it will not pass. It vibrates and makes loud noises at certain points in the Y-axis travel. I hear it both when trying to manually jog and self test. I cannot figure this out can someone please help? Do I need to recalibrate or does this sound like a defective stepper or component. FYI, the belt is still tight just like during initial assembly/set up and first several test runs. This issue seemed to pop up out of nowhere.
Napsal : 10/05/2020 8:02 pm
RE: Printer Crash During Build - Y-axis will not pass self test - New MK3S Kit w/ no previous issues
Hi Andrew
did you lubricate your Linear bearings on assembly ?(YES I know what the manual says)
Could you try doing this now please
https://help.prusa3d.com/en/article/i3-printers-regular-maintenance_2072#rods-and-bearings
then have another go!
Napsal : 10/05/2020 8:12 pm
Andy Ruth
(@andy-ruth)
@joantabb
No I did not so I guess I know what I am doing today 🙂 I will disassemble and lube the bearings per the instructions. Hopefully, that fixes it. Thanks!
Napsal : 10/05/2020 8:35 pm
Hi, Andrew,
have you tried the wiping Lube on the smooth rods approach, first, it may confirm or deny my thoughts before you go for a full rip down...
Joan
Napsal : 10/05/2020 10:49 pm
Andy Ruth
(@andy-ruth)
I disassembled the linear bearings and one of the bearings was binding so I applied grease into all 3 bearings. The difference is noticeable and I reassembled and calibrated, that issues is now resolved but......now I am having issues with my PETG sticking to the build plate! I have adjusted the z-height back and forth and the first layer calibrations goes well but when I run the PRUSA logo, all the filament globs up early in the process and wont stick to the plate. I am currently struggling with this. I have unloaded/reloaded the PETG filament and with the correct settings but no luck. Any ideas?
Napsal : 11/05/2020 2:18 am
Andrew
(@andrew-5)
I would bet on the bed being "contaminated". Wash and scrub with non abrasive pan sponge and hot soapy water (don't use the old one from the sink get a new clean pad). Dry well then IPA it and it should be fine. Shout out for Joantabb who told me.
Andrew
Napsal : 25/05/2020 3:04 pm
rmm200
(@rmm200)
With the Y axis, be really careful to not tighten the "UBolts of Death" too tight.
They can deform the bearing and cause binding.
Napsal : 27/05/2020 4:58 am
